DYNOJET: Power Vision and Target Tune question
I have a pretty good map in my bike for my current set up, but want to only address one section of it. My current map is not a Target Tune enabled map. Can I hook up my Target Tune stuff and do an auto tune session, like I used to be able to do the the auto tune pro, while not having a Target Tune enabled map?
Bob
The CAN network on the Dynojet products is universal among the product line. You can even plug the Target Tune or any of the Auto Tune modules directly into the dyno for sampling.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
cmashark (11-23-2017)
Yes, you can use your Target Tune module with the Auto Tune Pro application with a non-Target Tune map, you will simply use the CAN output from the module (just like the AT Pro), this will require use of the 72" CAN cable to connect the TT module to the Power Vision.
I since added different pipes<2-1>..etc.. I got a new 107ci base tune from dynojet, I remember the 20 min ride before anything, than do I want to do 3 <30> min AUTO TUNES? , thru the PV, and than let the target tune do its thing? I remember something about scaling the first tune, than capping after that? am I right?he sent a target tune enabled tune...I just forgot the protocol, literally is, set it , and kill em tuner..LOL
