The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
HARLEY: Tuning '17 FXSE 117" with SESTP
Old 09-05-2018, 11:18 AM
donk_316's Avatar
donk_316
donk_316 is offline
Bob. You are my tuning hero. Literally the only guy who will talk to me! Haha
Thanks man. The rear cylinder is seeing slight timing retard but only at WOT. It hit 2.5 degrees once other wise it was 0.5-1.5
The front is 0 all the way.
Old 09-06-2018, 05:25 AM
Slingshot383's Avatar
Slingshot383
Slingshot383 is online now
If the timing curves are the same in both cylinders, then that should tell you that some more fuel is needed at those spots where the timing is being trimmed.
Old 09-06-2018, 11:06 AM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
You want to be careful making that determination simply because it takes measurement to know whether ping is caused by too much timing OR not enough fuel.
Get the fueling close then the timing can be evaluated but never add fuel just for knock retard events unless the engine is starving and running crappy.
Bob
Old 09-06-2018, 03:59 PM
donk_316's Avatar
donk_316
donk_316 is offline
So i changed my displacement to 120cid based off of the software recommendations to increase displacement since i was maxing 1-2 cells out. I loaded the new map and then did an autotune run.
zero knock or knock retard. Bike runs like nothing i have ridden before... crazy.
Ill do one more AT and then i think im 100% happy with it... until the MVA heads this winter
GittinThere
15
07-06-2023 03:29 PM
Doughboy692
09-07-2018 10:19 AM
nico891
The Dyno Room
06-11-2018 12:52 PM
labellePjr
05-03-2013 09:22 AM
odey1979
07-02-2012 05:28 PM
Quick Reply: HARLEY: Tuning '17 FXSE 117" with SESTP
