The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
HARLEY: SEPST 103 with 204 Cam tuning file #
Old 09-06-2018, 08:12 PM
YVON BILODEAU's Avatar
YVON BILODEAU
YVON BILODEAU is offline
Default SEPST 103 with 204 Cam tuning file #
Can someone Tell me the file number to use for the screaming eagle pro street tuner .
I have a 2016 Breakout 103 with heavy breather and SE mufflers with the SE 204 Cam.
Thank you!
Yvon
Old 09-07-2018, 05:12 PM
donk_316's Avatar
donk_316
donk_316 is offline
A41000411A is a basic stage 1 tune (intake and pipes)
A41000412A is stage 1 with a SE585 cam
A41000414A would be too much (259E cams, CNC heads and 58mm TB
Maybe try different years, like 2015 or 2014 in the selection settings.
Old 09-07-2018, 07:28 PM
YVON BILODEAU
I have Search and didnt find anything for the 204 ...
Surely There is one .
I have a stage 1 on m'y bike
For the stage 2 they have the tune but for a SE 585 Cam .
Thank you for your response!
Old 09-07-2018, 07:35 PM
YVON BILODEAU
Maybe I could use the stage 2 map with the 585 Cam for a base setting and then Do some smart tune ...
Old 09-07-2018, 07:56 PM
donk_316's Avatar
donk_316
donk_316 is offline
I would compare your cam to that cam and make sure the intake open / exhaust close timing are very close to the same.
That's me though, I'm not a pro.
Old 09-07-2018, 08:13 PM
YVON BILODEAU
Good point... thanks
I want to use the 204 cause I dont want to change valve spring .
Anybody used the se 585 with stock spring and lifters ?
Old 08-05-2019, 06:50 AM
leafman60's Avatar
leafman60
leafman60 is offline
YVON, did you ever get your engine tuned in for the 204's??
I have been using the 204 cams for a while and they are fantastic. They give good low end torque but also maintain good boost all the way up to redline.
The 204's are very different from the 585 cams so I would not think tuning for a 585 would be similar.
I am using the Vance and Hines Fuel Pak FP3 as my tuner. Fantastic.
Old 08-05-2019, 08:41 PM
YVON BILODEAU
Yes I did and it ran great ...but lately I installed V&H big radius exhaust and I lost some power ...need another tune !
Silentwolf680
Milwaukee Eight (M8)
05-02-2018 10:18 PM
FTP ACAB
03-30-2018 09:11 PM
tj66
Engine Mechanical Topics
17
06-01-2017 04:51 PM
KarmaKatt
01-04-2015 04:31 PM
W0ace
02-27-2011 11:36 AM
Quick Reply: HARLEY: SEPST 103 with 204 Cam tuning file #
