The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
DYNOJET: P0155c code after getting it tuned.
Old Sep 12, 2024 | 12:47 PM
WS6_Keith's Avatar
WS6_Keith
Originally Posted by ZDeuce
Like I said earlier, when I looked at the tune in WinPV, closed loop was turned on but also ignored. And when I looked in Quick Tune on the PV, closed loop was not checked. So today I checked the box for closed loop in quick tune and went for several rides and have not had the code come back yet. I'm not sure if the PV4 has something similar to quick tune, but I would look there first. If not, go into WinPV and make sure closed loop is enabled and not "ignored" and reflash your tune.
Ignored in the software means when the tune is written back to the ECM, that setting will not be changed. Whatever is in the ECM will stay. You have to check the box to no longer ignore that setting for it to be "respected" when the tune is flashed to the ECM, if you wish to change that parameter.
Old Sep 17, 2024 | 04:58 PM
FLTRI17's Avatar
FLTRI17
If all else fails call Dynojet. If necessary, they can take over the installed? PowerCore software PC computer to go in and check out the calibration setup and PV 4 settings. That way they have control to figure out the issue(s).
IME very few tuners like or willing to tune using PV4. That said, a tuner can send the tuning license from the PV4 to a PV2, which is much more tuner-friendly than the PV3 or 4.
Let us know what you find as the problem. You are missing a portion of the tuning by not utilizing the O2 sensor that compensate for different fuel blends found from one station to another as found all over the country.
Bob
Old Sep 17, 2024 | 05:59 PM
Tha_Big_Ohh's Avatar
Tha_Big_Ohh
Thank you guys for all your suggestions, I’ll contact Dyno jet and see what they say about fixing it. I haven’t been able to do much for the past week or so because of the accident, I have surgery scheduled for tomorrow for my hand and knee. Pins and bone fusion’s, how fun.
IgnatiusMaximus
Sep 16, 2022 10:52 AM
Jrotten65
17
Jan 26, 2022 08:34 PM
just plain john
Oct 8, 2017 12:44 PM
jp13
Electrical/Lighting/Alarm
Oct 10, 2015 04:34 PM
Highgrade
Oct 1, 2015 06:57 PM
