Change lifters or don't
My 2012 RK has 12000 miles on it and I am fixing to put 57H cams in her. I would settle for a set of se204 but cannot find a used set. Should I change out the lifters or keep the stock ones. Also I read where comp cams 850 lifters will work in the twin cam motors just fine?
Originally Posted by Flhrhog
(Post 13458105)
I'm in the same boat with my 2004 RK tc88. I'm doing the tensioner upgrade with cams and adjustable rods. The engine has 29k miles on it. My service writer says the stockers are fine and I don't need new tappets.
I would go ahead and change them out while you have it all apart. I didn't and had to go back and change them later. Woods, gaterman, s&s, and other good choices are all better than hd stock lifters. Imho.
Change
I didn't change mine, reasoning that had I not done cams I wouldn't have changed them. If you go with adjustable pushrods it's not that hard to change lifters.
Change them for $200.00 or less it's worth the peace of mind.
Which ones would you guys recommend for less than $200?
I would change out '12 lifters. Comp lifters are fine but if ya want to spend more for some reason go S&S.
Its really a personal choice on lifters
I would go S&S. But it will be more than 200 On the other hand. If you dont change an engine repair or replacement is more than 200 as well Dont skimp on lifters. |
| All times are GMT -5. The time now is 04:31 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
