Road King Cam tensioners issue....
I have read on this forum in the past about issues with chain cam tensioners on earlier 2000Road Kings. I looked into that issue, due to the fact I recently purchased a 2002 Road King,and discussed that issue with the service manager at my Harley dealer. He assured me that I shouldn'tbe concernedabout it. The problem was discovered and solved. He stated that the problem arrose in early 2000 Road Kings andthat it is a non-issue after 2000.He told me the problem was due to the supplier of the chains that Harley was using, thier chains were defective. The chains had a sharp edgeon one side of them and that was causing the problems. Harley got another chain supplier and the problemis longer an issue. The service managersaid he has only seen two problems concerningcam tensionersin the past 7 years, even on bikes with over 50,000miles. Don't know if he is just giving me BS, but I thought I would pass it along.
RE: Road King Cam tensioners issue....
Find yourself another dealer.
Ditto what was said about the tensioners being a wear item on pre-'07 bikes. Your SM either lied or he is new and ignorant. Mine were shot after 40K, others fail much earlier or later; some never fail. My service manager, and others here on the forum, have said that the tensioners should be checked after 25K.
I echo everything that's already been said. I have a 2001 Road King and experienced significant engine damage when my cam chain tensioners went bad at 27K. What really irked me was that no mention of the issue was made by the dealer when I had my 25,000 mile service performed. Needless to say, I got no relief from the dealer or H-D on the expense I had to incur.
I recently purchased a pre-owned '04 Road King Classic with 20k miles, during my discussions with the independent shop owner where I was buying the bike, I brought up the chain tensioners he recommended changing out the OEM chain-driven cams with the S&S 510g geared cam set. I agreed if for no other reason it is one less maintenance headache to deal with. The change out costs about $1200.00, labor included, to have somebody do it for you. Of course the price comes down if you can do it yourself.
ScooterJammer
ScooterJammer
Does anyone know if the problem continues on the Screaming Eagle engine conversions? I have a 2001 Road King Classic that I purchased last year. This bike had the engine upgrade to SE. I don't know if this would have been something normally changed outduring the upgrade. I have a about 2K on the new engine and 12k overall. Thanks
Z
Z
