EFM or Rekluse Auto Clutch or ???
I spent a lot of time at the Rekluse booth during Sturgis this year. I almost had them install one because of their $50 installation offer but then I decided that EFM may be the better option. The Rekluse clutch has a lot of wear parts and the rep told me that they recommend checking the adjustment every ride! That being said, many riders have tons of miles without adjustment. The EFM guys say that adjustments are not necessary once their unit has been installed which really appeals to me - I have enough to check and adjust on my bike as it is!
My limp wrist loves my Rekluse. The Rekluse has 11 disks instead of the stock 9 discs and is supposed to handle more torque. Call them and ask for examples. My HD dealer is an authorized Rekluse dealer and has installed a lot of them. I ordered mine the day I rode my new bike home and no adjustments needed after initial setup. No issues with a bit over 7k miles so far.
Thanks Daverino; I also like my Rekluse and would do it again but have two issues. First, my wife & I do a lot of cruising in sixth gear (2015 Street Glide) at 45-50 mph on cruise control with RPM between 17-1800. The Rekluse does not lock up under 2000 so any throttle increase, even a slight headwind, requires a downshift to avoid clutch slip. I've adjusted the clutch repeatedly to no avail but to be fair my bike is mildly modified (stage II; cam/headers/pipes/air cleaner/programmer) and makes more power than stock (100 horsepower,115 lbft of torque). The other issue is the gear indicator no longer works after Rekluse installation. Mine is now blank; others have reported that theirs reads incorrectly. Rekluse has told me both issues are normal & recommended either changing my riding style or installing a stiffer clutch spring. I think these issues should be stated by them in their ads since many of us have mildly modified bikes; like to chug around; and like their gear indicator. Regardless, next week I am installing a CVO Screaming Eagle clutch spring (part #37951-98) to hopefully remedy the slip issue. There is no cure for the MIA gear indicator.
I had to readjust my Rekluse Auto Clutch no less than 14 times in 37 months of ownership on my 2015 Road Glide CVO. It finally needed to be replaced 2 months ago at 53,240 miles on the Rekluse.
I’m back to running my OEM clutch which had only 10K miles on it before going with the Rekluse up in Daytona during bike week in 2015.
I’ve called Rekluse early on about the many adjustments I went through and was told to keep the RPMs above 2,400 RPMs. This didn’t help much. The hydraulic clutch adjustments weren’t hard to do, I just got very proficient doing them even in parking lots.
The Rekluse was great when it didn’t need adjustments which became a pain in the backside doing them so often.
I’m approaching 70K miles on my Road Glide, if I continue to own it I’d like to install the EFM Auto Clutch next since they claim no adjustments will ever be required.
https://www.motorauthority.com/news/...ug-your-engine
Puglia10 (01-09-2019)
