TW222's
Looking on fuel moto web page on cams and looking at the tw222 and one dyno sheet shows a pre 14 with these cams and a stage 1 and it picked it up 20hp and 20 foot pounds of TQ and went to the Rushmore project blog and seen a 2015 road glide with different air filters and exhaust making with in 6hp and 4 foot pounds of TQ with stock cams of the full stage 1 TW222 pre 14. Looks like the 14/15 cams make good power. How many people want to spend $390 for cams and another $150 push rods and to some people having to pay labor to do the job to pick up 6hp/4tq. Looks like the way to go is buy a set of take out 14/15 cams for less than $80 on ebay and with a good air filter and exhaust and a good tune and make 89hp and 108Tq on a pre-14 vs the $540 222s and push rods and make 96hp and 112tq. I am glad I found them dyno charts and seen this but wish I seen it before I bought the 222s and push rods to put in my bike because I already put the 14/15 cams in mine. Oh and done a little checking and the 2014-15 cams lift is .309 X R/A ratio of 1.65=.50985 lift close enough to .510 lift.
Originally Posted by 96inchBOB
(Post 13527466)
Mark |
No doubt it's a very good upgrade for the the money...... With that said its hard for me to spend time or money on something like that knowing I'm leaving power on the table. I guess it just comes down to what you want to spend and the results your after. There is more to cam choice than your final numbers also, torque curve, fuel milage, engine temps, ect. You won't regret your 222 purchase im sure.
The new 14/15 HO cams come in the touring bikes, they also have a bump in compression which helps the power output, be careful which cams you are looking at if you choose to go with the Harley cams. the new HO 103 cams are similar to the 255's with less lift, but do work very well with the correct intake, exhaust and tune. Good Luck
Originally Posted by roadglider05
(Post 13528605)
I think the 14 cams are fine, I had the 2014 Limited with those cams and twin cooling, small mods like slipons, a/c and nightrider 02 modifiers and it ran excellent. May leave the 255's in the CVO Limited with some external mod's only as it runs excellent also.
A Woods 222 cam is an excellent choice of cams. I would of installed the Woods directional lifters with it.
The 222 cams with HF air kit and exhaust gives you more than a little extra power. If you had of bought the cams from Fuelmoto, And got a PV tuner. He would of gave you a map for free. We have installed the 222 woors cams in 3 bikes with the PV. One of the bikes was a 2010 SE Sg with a 110cu that we took out the SE255 cams. What a difference the 222 cams made , with the PV and the map that we got from Jamie. We used the SE TAPERED quick install push rods. Excellent power, really woke the bike up. But we have a High flow air breather ,and it had some stainless header pipes from Fuel moto and some jackpot exhaust on it. I got a kit from fuelmoto. Did a 107 with the level B heads and Woods 555 cams. All I can say is the bike screams. If you had of wanted a custom map , I would of gone to Tman at Tman performance in N.C. Thunder-Heart performance is also in White House Tennessee. |
Originally Posted by cardboard
(Post 13529338)
If you had of bought the cams from Fuelmoto, And got a PV tuner. He would of gave you a map for free. We have installed the 222 woors cams in 3 bikes with the PV. One of the bikes was a 2010 SE Sg with a 110cu that we took out the SE255 cams. What a difference the 222 cams made , with the PV and the map that we got from Jamie. We used the SE TAPERED quick install push rods. Excellent power, really woke the bike up. But we have a High flow air breather ,and it had some stainless header pipes from Fuel moto and some jackpot exhaust on it. I got a kit from fuelmoto. Did a 107 with the level B heads and Woods 555 cams. All I can say is the bike screams. |
(Post 13529379)
I can see where the 222's will makes good improvement in a pre-14's bikes like the bikes you mentioned. I do have a PV on my bike and I do have the 18404-08 tapered push rods. I have the 14 HO cams in my bike and the 222s will not help it as much as it does a 2013 and back that is what I was saying and don't think I will be happy for the $$$ I spent vs power gain but they are going in and I will see. If it is close and I hope it is a lot better power but I dought it will be and they are quite as what I have now they will stay in and if not to ebay or in the form classifieds they will go. It don't matter what lifters I have either I know they are as good as anybody's harley cool aid lifter on the planet more than likely are better and the company has the back bone to tell you who makes them for them something the harley cool aid lifter people want tell you. I hate cool aid and want drink it.
He can tell you what they will do for your bike. The 222 cam is for a STOCK bike , With a HF air kit and free flowing exhaust. The Woods Directional lifters are what Jamie uses. And Bob Woods. They quieten the moto down from the agressive ramps on the woods cams. And you don't worry as much about the lifters going bad. They are all that Wolfgang Grassersuses also. |
(Post 13529388)
Pick the phone up after the Holidays and call Fuelmoto. Jamie sells the Woods cams. And is using them on all the new bikes.
| All times are GMT -5. The time now is 01:29 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
