Anyone use Seafoam Spray on their intake?
Read this thread, specifically starting near the end of page 2. It references the seafoam and a couple other ideas I think you'll fine useful.
https://www.hdforums.com/forum/touri...ncluded-2.html
jeez just get a sensor specific cleaner- squirting oils or other petroleum products in you intake may have unexpected consequences.
any auto parts store will have what you want- and instructions on how to use.
on my truck, removing the maf sensor was required to clean it.
if you have a points ignition and a carb like most of my stuff, do what you want ( including spraying water from the hose)
when it comes to computer controlled motors, adding something which may skew the sensor outputs can be tricky not just the sensor in the intake but the o2 sensors too.
I'm the guy whose vehicle failed smog after adding SF for the 1st and last time...SF said to run a couple of tanks through- after which I passed no problem.
2¢
mike
2¢
mike
Use the wrong stuff, fry a couple of O2 sensors at 200 a piece or trash a converter or other sensor and you are FUBAR'd
Personally I use MAF sensor cleaner, it is going to clean the intake tract and not destroy any sensors.
Cripes RTV gasket cement can fry O2 sensors from the vapors it gives off, so you need to watch what you pour in the engine through any opening
correct.
I mispoke, using a generic kinda term above.
we have a tmap sensor.
either way the function of the sensor is to allow the ecm to determine the density of the air ( how much oxygen) and add fuel to match.
commons sensors for this function will be
tmap- temperature manifold absolute pressure
map- manifold absolute pressure
maf- mass air flow
mike
maf- mass air flow
mike
