Twist Grip Sensor Wiring Question
I'm putting the wiring back in the connectors after a bar swap. The twist grip sensor (TBW) wires are a different color on either side of the connection, so I can't just match the colors from one side to the other. Most wires on the main harness side have stripes that match the solid color wires on the sensor side, so that may help.
I thought I still had the sketch from the last swap but I cant find it anywhere, and the service manual doesn't give me the answer I need- does anybody know what colors need to match up?
It's a 2008 Touring.
It looks like my wires are different colors. It's an FLHRC, but I don't think that matters for the twist grip sensor? Also there's no yellow side anywhere, just a black 6-wire molex connector with no markings.
I should clarify- this is the connection in the bucket, not the green plug in the bars.
Pretty sure I got it- wires are installed like this picture- although the "black side wires" are completely different colors than described. Mine have stripes that match the "yellow side wires" which I deduced means the bar-end side since the insulation starts as yellow up where I can no longer see it, but is black where it's exposed from the bars.
FenderGuy53
08-03-2013 04:42 PM
