15" Road Glide- Ignition Switch issue- Help!!
Old 02-12-2015, 01:42 AM
louisluongo's Avatar
louisluongo
louisluongo is offline
Stage I
Default 15" Road Glide- Ignition Switch issue- Help!!
Locked the new Glide Special up last night, turned the wheel and the ignition switch, put the key in and locked it. No issues.
Came out today to unlock it and the switch wont turn out of the fork lock position. It unlocks fine but I cant turn the switch and the forks are locked in position.
How do i get it to the dealer to even have it fixed, under warrenty i hope, if the wheel wont straighten.
Any advice??????
Old 02-12-2015, 02:39 AM
14 FLHX's Avatar
14 FLHX
14 FLHX is offline
I haven't done it in a while, in storage, but I think i have to push down on the lock to unlock it after you unlock it with the key.
Old 02-12-2015, 07:35 AM
Trial dog's Avatar
Trial dog
Trial dog is offline
Depending on how you bike is parked, there could be slight pressure on your wheel, sort of putting torque on your steering. So grab a handlebar and while turning the unlocked switch move your bars to take pressure off the switch (could be either direction) and it will likely turn right on.
Old 02-12-2015, 07:42 AM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
That's either a very long ignition switch.... or a very short Road Glide...
Obliterator_21
05-19-2015 10:59 AM
Watchfuliz
2014+ Touring Models
16
01-17-2015 09:40 AM
gwphelpss10
06-14-2012 11:36 AM
FunkyNova66
09-26-2009 07:32 AM
Born2cure
09-12-2008 03:11 PM
Quick Reply: 15" Road Glide- Ignition Switch issue- Help!!
