Tw777 adj pushrod length?
Anyone save any measurements from their tw777 cam install? I'm using night prowler lifters that came with my fuelmoto 107ci kit.
I after adjusting push rod I got .400, .425, and .3xx between my lock nuts after adjusting for zero lash and using the "four turns and two flats" on the bottom. Let the lifter sit for a while and did the next.
Why are my measurements not symmetrical? I didn't do the front exhaust yet since I assumed something isn't right... I also had both lifters bottomed out and the piston at tdc
Thanks
Jake
Thanks
Jake
The first 2 were exhaust and intake, which are expecting to be a little different according to fuelmoto. But my rear intake was .400 and the front was .377 between the lock nuts after procedure, are these acceptable tolerances??
Not sure why my front intake is shorter? When turning the engine by the tire in gear, I don't feel any binding in the rear... Maybe just being ultra paranoid, I have bugged FM a few times and have been helpful but they aren't available on the weekend
Jake
Jake
Jake
Jake
After you have found 0 lash you should sink the PR .140 thous deep into the lifter. The exhaust PR's are longer than the intakes. Just make sure that your piston is at TDC on the compression stroke when you make the adj. You can also go to Several sites and see the proper procedure on adjusting the PR's but there is one on Big Boyz that I really like. This is something you want to get right and if you think it's something out of your wheelhouse I'd find a good indie to help out !!
You guys are like motorcycle therapist. This build has been keeping me up at night $$$.
I redid the front intake and came up with .378 so pretty identical. I measured .232 at zero lash.
So I lengthened it approx .146, which is close enough to .140 for me. I am just being the nervous nail biter I think....... Not even sure if my caliper is even that accurate
THANK YOU EVERYONE!!!!!
Finishing the small stuff today, and made a final appt for a dyno time on Tuesday. Might have to go to work while they run it so I don't have an anxiety attack and tip over like a faint hearted *****.
Jake
Jake
Dyno work is done-ish
I'm having a little bit of "rocker arm tapping the cover" noise. It gets louder under load so that makes me think it may just be an exhaust leak. Going to check it out tonight with a hose to my ear. Maybe just me being paranoid about a little extra noise from the new cam and lifters
Jake
Jake
