Auto tune no trims issue
Old Apr 18, 2015 | 09:20 PM
aroacha5446's Avatar
aroacha5446
Default Auto tune no trims issue
Sooo I've had auto tune working fine, receiving trims. But as soon as I changed the AFRs to a leaner setting I have yet to receive trim adjustment. Anyone have the fix.
Old Apr 18, 2015 | 09:39 PM
Webo's Avatar
Webo
So much missing information here. Can we start with what tuner you using?
Old Apr 18, 2015 | 09:46 PM
aroacha5446
Power commander V. The auto tune was working perfectly fine until I switched the AFR map
Old Apr 18, 2015 | 09:49 PM
Webo's Avatar
Webo
I'm not a PV user so I'm going to defer to others here. But are you sure that you are in autotune mode still? With the SEPST once you make a change and flash back to the bike you have to enable autotune again. Just a stab at it...lol
Old Apr 19, 2015 | 08:23 AM
aroacha5446
I'll have to check that out
Old Apr 19, 2015 | 09:03 AM
SavageChopper's Avatar
SavageChopper
Make sure you didn't set your AFR tables to 0. Also check to make sure auto-tune is still on. You should see AFR data while idling with a PC connected to the Power Commander. I believe there is a 60 second delay before AFR data shows up. You should also check that you are seeing engine temp data since auto-tune is usually set to work above a certain temp.
Old Apr 19, 2015 | 09:21 AM
aroacha5446
I'll check, the AFR values are still good. Rode the bike for roughly 20mins came back still no trim values
Old Apr 19, 2015 | 08:22 PM
aroacha5446
Anymore ideas might have to wait to call dynojet
jt metal
Aug 14, 2022 07:40 AM
fuelmoto
Fuel Moto / Jackpot Mufflers
Aug 8, 2018 04:39 PM
aroacha5446
May 10, 2014 05:50 AM
gize
May 3, 2013 12:27 PM
Rambone1570
Dec 24, 2009 07:11 AM
