Dresser Duals
Dresser Duals
Finally pulled trigger on vh dresser duals. I will have to get exhaust gaskets. Anyone have any recommendations? Also does the crossover need a gasket too? If so what do I need to get? Anything I need to know before I install these or tips that would make install easier. Thanks
Make sure you "remove" all the old gasket from the exhaust ports. You want a perfect seal. It's a real tight fight, if you force it the gasket will get distorted and ruined. Freezing them supposedly shrinks them a little bit to make them easier to press fit in.
Also follow the torque sequence for the exhaust port bolts as well. Re torque after a few heat cycles as well.
Make sure you "remove" all the old gasket from the exhaust ports. You want a perfect seal. It's a real tight fight, if you force it the gasket will get distorted and ruined. Freezing them supposedly shrinks them a little bit to make them easier to press fit in. Also follow the torque sequence for the exhaust port bolts as well. Re torque after a few heat cycles as well.
2010 Limited with some stuff
That's not been my experience.
I'm not a Harley mechanic, just work on my own bikes, and a couple wrecks I've rebuilt for fun. In the last 10 years I've installed 4 sets of Dresser Duals and last month 2 sets of Power duals all using the gaskets supplied by V&H or HD SE gaskets with no problems.
