Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Touring Models (https://www.hdforums.com/forum/touring-models-11/)
-   -   Rinehart Q'S (https://www.hdforums.com/forum/touring-models/1051294-rinehart-qs.html)
je3169 Jun 4, 2015 01:34 PM
Rinehart Q'S
Rinehart XTREME TRUE DUALS if so how do they sound compared to V&H?
How is the fit any info is wanted good or bad.
Thanks
equandt Jun 4, 2015 04:01 PM
The Rinehart Extreme True Duals sound awesome...they have the classic Rinehart true dual sound.
The fit and quality is great. I have no issues after 2 years with them. Installation was straight forward and easy.
je3169 Jun 4, 2015 04:18 PM
Thanks for the reply.
Kahuna Jun 4, 2015 05:59 PM
I have the true duals on my RG for the past 8 years and they are still pretty awesome. I like V&H as well, but they are less throaty than the Rineharts. I love the deep rumbling sound, but not obnoxious.
Thanks
kylebru1 Jun 5, 2015 07:29 AM
I just added the Xtremes to my 2011 Electra Ultra classic. Im not that mechanically inclined and I got them on if that helps. The only issue I had was with the transmission mount/bracket on the rear head pipe going under the bike. It was a real bear to get on.
I took the bike out last night, and the sound is great. If you really get on it there is some good bark, at idle its not crazy loud. I can still hear my radio at highway speeds. All in all I'm very happy with them.
je3169 Jun 5, 2015 07:36 AM
Thanks for the reply 👍
Nathan81 Dec 5, 2015 12:26 PM
Question, how did you end up getting the transmission mounting bracket on for the rear head pipe? I'm installing now on a 14 SG and the tabs of the bracket look like they should go in front of the plate closest to the bolt head but it only seems to want to fit with the tabs behind the plate on the thread side of the bolt...
decencyxdefied Dec 5, 2015 12:45 PM
I installed a set on my neighbors 11 cvo and he loves them
Nathan81 Dec 5, 2015 12:51 PM
Im working on getting the transmission bracket on as well.. Not sure if I have installed correctly but this seems to be the only way it will fit..
https://cimg1.ibsrv.net/gimg/www.hdf...cb6472c75.jpeg
https://cimg2.ibsrv.net/gimg/www.hdf...50e75cb90.jpeg
a3dad Dec 6, 2015 05:30 PM
The hanger has to go on the other side of the bracket and the bolt is in the wrong direction. I'd loose fit the exhaust until you get this to fit properly and then sung-up starting from the heads backward.
© 2026 MH Sub I, LLC dba Internet Brands
