2005 road king custom 1500 backfire
this 2005 raod king custom came from colorado, just a few miles from the rockies . wondering if the fuel/air mix is different in colorado than in ohio? it does have after market pipes.
the bike back fires when in low rpms, mostly in 3rd. pipes pop, then carb sucks air then runs good again. bike also has backfired when getting on the gas. bike backfires more when in low rpms.
thanks for looking, i am looking at other posts on this site and they are helpfull. i just do not have time to read all posts.
stoney bagger
stoney bagger
stoney bagger
stoney bagger
Carbed or fuel injected??
Sounds like a lean condition......
The elevation will make a difference in the F/A mixture of a carb.
Going to a lower elevation would need a larger jet in the pilot and the main.
I would go one size up and try that to see.
Do a couple of plug chops to dial in the mixture.
Fuel injected doesn't need any fuel related tuning, that I know of.
Air leaks in either type will give backfires and popping also.
plugs where white, filter was good had a little oil though.
carb looked clean, bladder in carb was good.
seemed like air was coming from the front pipe, looking more into that pipe.
starting hear different sounds from bike, not sure if they are good sounds.
i am going to look at a Fuel Moto PCIII.
thanks again for the info
Those are for FI bikes
Check the seals around the carb, manifold and head spigots for air leaking causing a lean popping.
Spray some WD40 around the seals and if engine changes pitch or sound, you got a leak somewhere.
