new tires= wobble
new tires= wobble
I've got a 98 electraglide and every time i put new tires on i get wobbles at about 75-80 mph. its not really a death wobble but just a rocking back and forth, if a do a quick push on the bars it will do it pretty bad and takes a bit before it settles back down. This has been the case every time i change tires. first set were continental milestones, then metzeler me 880, metzeler 888, and now a set of shinko tourmasters. this will go on for about the first 2-300 miles and then ride out like a champ for the rest of the life of the tire. The tires never show any odd wear on them and I get average miles per set. I've replaced swingarm bushings, and put in the race tech gold valve emulators while running the metzeler 888 and I do wheel bearings everytime I change a tire. So any suggestions on what I may have going on or just get used to having a bit of a nerve racking few hundred miles every time i get new tires?
Keep in mind this happens with every new srt of tires so 4th time now. Tires are seated fine and the neck bearing test for a bagger being pull the bar to one side and let go shows it to be just a touch tight. If it were a neck bearing issue why would it only show itself for the short period after a new set of tires?
About the only thing that can change to where the tire stops doing that suggests the bead. I know when mine did it, it was the bead & just looking at it, it was not noticeable. But that is what it was. As for the fourth time, it could be that the rim is just tight enough that it happens every time. Good luck.
Toby
Toby
