Inner Primary Removal Help. - What am I missing?
I have the compensator, clutch pack, Chain tensioner, starter (pushed back) and all the bolts removed, and its hung up on something. seems to be the bearings that the main shaft comes through. I thought they were pressed in to the inner primary. I tryed to gently pry it off with a pry bar, but I'm afraid to really crank on it in case i missed something.
What am I missing here, can't find anything I missed in my manual, but it doesn't really have much in there for this, unless its somewhere other than the primary chaincase section.
What year is your whip?
You are right, the bearing is pressed into the back of the inner primary, the race is pressed onto the main shaft.
Could someone have replaced the IP bearing and race combo with a sealed unit from baker or jim's? And the center of the sealed unit has seized into the main shaft?
Got another question for ya, it looks like it's my shifter seal that's leaking. I pulled the snap ring and the washer, but I'm not seeing any seal in there. Does something else need removed to access the seal?
I don't have my seals yet, the ups guy should bring them tomorrow. I have a main shaft seal coming too. I'm planning to pull the sprocket to look at it, but I am thinking the shifter shaft seal is th culprit.
What do you think? Worth pulling the sprocket just to be sure?
