Need Side Panel Removal Help 07 E.G
Hows the side panel held on ? I figured it may be a pull off/ push on set up with rubber grommets ?
Whats under each side as painter wants a panel to paint match bike Thanks |
They just pull off. Each one has three tabs that go into rubber grommets. There's a tab on each corner on the top of cover and one in the middle of bottom of cover. Removing the saddlebags makes it easier getting them off. As far as what's under them, under the left side is the fuses and cruise control module. Under the right is the ECM and other plugs.
Perfect , thgh they might and wasn't looking to brake them yet
Thanks |
© 2024 MH Sub I, LLC dba Internet Brands
