Engine upgrade
Old Sep 3, 2015 | 08:09 AM
BuzzL's Avatar
BuzzL
Default Engine upgrade
Talked to Brian at Fuel Moto, looking at going with the CNC port and polished heads. Also upgrading cams to the TW-777, along with polishing the TB. I also would like some thoughts from you guys on going with HC pistons. Any recommendations on what pistons to go with. Screamin' Eagle, CP, MTC, etc. Thanks for the help.
Old Sep 3, 2015 | 10:03 AM
qtrracer's Avatar
qtrracer
If you are going fm heads then get their 107" set up at the same time. Send them your cylinders and they will send you a set that has been bored and honed to the pistons. They will get you set up with the right cams to get you the right ccp for your liking. I use CP but I'm sure whatever fm uses is fine too.
Old Sep 3, 2015 | 11:29 AM
0ldhippie's Avatar
0ldhippie
I like Mahle pistons but if ya are doing FM heads why not just get their whole kit?
Old Sep 3, 2015 | 12:39 PM
mkguitar's Avatar
mkguitar
as above a kit or package approach will give repeatable results, motor after motor.
FM has a great name ( I don;t use) and they offer many package variants with dyno charts showing results.
pick what you like and go with that.
don;t pay so much attention to peak power numbers, but look at the curves in teh rpm areas which you use- take gearing and weight into account.
there are other builders and kits and you should look into those as well- and ask them for recommendations.
the guys who are out there are running top flight shops and not fly-by-night. although some of those are still around.
but buying a kit means that someone smarter has already done the thinking for you
mike
Old Sep 3, 2015 | 08:29 PM
BuzzL's Avatar
BuzzL
mike
How much torque do you think the stock crank could handle? Was reading in this forum and the question was raised. I guess it would depend on your riding habits?
Im not a WOT kind of rider, just would like having the added power if I need it.
Old Sep 3, 2015 | 08:47 PM
qtrracer's Avatar
qtrracer
If you are looking for guarantees on reliability, there isn't one. I am running close to 130 sq on my 107" with a stone stock bottom end. I am not delusional in thinking that it will hold up forever. I have accepted that it may come undone tomorrow. If you up the power you will be in the same situation, a hand grenade with the pin out. Might be today, might be tomorrow, but it will blow when we do to these things that we do to them with a stock bottom end. I am ready to pull it apart soon to do the bottom end, might stay 107" might go 117", I don't know. Depends on my mood, LOL
rons73
Dec 14, 2018 12:49 PM
cycler
Mar 10, 2013 12:14 AM
62pan
Screamin Eagle CVO Models
Jan 18, 2011 06:04 PM
canyonwlf7
May 31, 2009 04:34 PM
Marsh
Aug 13, 2007 12:50 PM
