progressive 412's
2005 ultra
found a good deal on a set of 13.5" progressive rears,, any body run them on a touring bike like an ultra ?? i'am only 170lbs. so I think they should be ok ,, if so what setting would be good 1 up ,, I was figuring setting 2 to start with . thanks mike |
I have 412's and they are just OK.
I'm looking to change mine for Ohlin's or Progressive 970's. But still, 412's are better than stock. |
Originally Posted by Zeus55
(Post 14485730)
I'm looking to change mine for Ohlin's or Progressive 970's. But still, 412's are better than stock. mike |
I contemplated the same. Went Ohlins, huge diff and never looked back.
Originally Posted by jmn1960
(Post 14485755)
what setting are you running them on ,, if you don't mind ,, how much you weigh
mike When we ride 2 up I go to the third knotch but I ride solo 90% of the time. |
Those shocks can come with a standard spring or with a heavy spring. At your weight the heavy springs will be too stiff. Probably would be a good idea to ask what spring it has then visit Progressive's website to see if they will work for you.
I am 215# with the standard spring and have mine set 1 notch down from the stiffest setting. I agree that they are OK, a good buy for the money and much better that the stock Harley air shocks. |
Originally Posted by EG-2006
(Post 14486143)
I am 215# with the standard spring and have mine set 1 notch down from the stiffest setting. I agree that they are OK, a good buy for the money and much better that the stock Harley air shocks. mike |
| All times are GMT -5. The time now is 12:22 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
