Truck lite passing light
10-24-2015, 12:29 AM
I have truck lite head light and passing light but one of the passing lights doesn't light up very bright, in the day time you can hardly tell its on. What could be the problem bad connection or bad light?
10-24-2015, 05:29 AM
Could be either, switch it to the other side and see if it lights up any brighter.
10-24-2015, 05:31 AM
My guess is faulty light...call for replacement & swap.
10-24-2015, 06:20 AM
Verify the ground, and input voltage. I too guess faulty light. Did you try replacing the original light to see if it was brighter?
10-24-2015, 07:44 AM
Swap 'em around, go from there. Bulb? - replace. Connection? - repair.
And when fixed, get the aim correct on those, with the TLP7 that is a must!
10-24-2015, 08:04 AM
Remove and connect directly to a battery, instead of double work removing both.
10-25-2015, 04:12 PM
I have the Phase 7 truck light headlight and passing lamps. My son was ahead of me and couldn't tell if the spots were on. The spots work great at night but during the day, not very visible. I usually use the high beam during the day. VERY NOTICEABLE!!
kanelakos
Milwaukee Eight (M8)
07-25-2017 08:18 AM
KJBennett
2014-2023 Touring Models
10-15-2014 08:02 PM
izhd
08-20-2014 07:39 PM
71FLH_russ
Shovelhead
02-23-2012 07:51 PM
horsepower
08-20-2011 10:46 AM
