I have attempted to load the accel pump function into my PCIII. Once I enable it and then go to the main software and adjust the accel pump settings I click OK, then click on Send Map.
The accel pump mode is actually part of the PCIII not part of the map. Once it is enabled, you must be connected to the PCIII to make any changes in the settings. Once the settings are set you just click OK and you are done. Again this is all done while connected to the bike. If you run the program without being connected you can not access this mode. The accel pump settings should stay as set even if you load a different map also.
At least this is my understanding of the way it works. You can find more information at the Power Commander web site.
