21" RK Front Wheel Question
The '13 and older bikes "usually" require nothing. But it's a super close fit. The '14 and newer bikes require adapters that raise up the fender. I assume you are talking about your '06. If that's the case, CHECK IT! tape something small to the tire and make sure it spins threw. In my case I was right at the almost touching point with my 21, so to not risk burning the paint should the tire ever run low on air and grow, I raised the fender. Most people don't worry about it, and just bolt the 21 on and go.
Usually all that's needed is to drill out the rear mounting holes with (I think) a 3/8 drill bit. Lift up on the back of the fender, and re-tighten the bolts. I watched a couple guys who, after they drilled the rear mounts out, super glue a piece of toothpick in the hole to assure the fender didn't drop back down as they were tightening the bolts back up. But having a friend pull up on the fender seems to work just as well. Just remember too re-check and re-tighten after the fist day or two, to ensure the bolts are tight and the fender doesn't slide back down.
I wouldn't drill my fender, bolt the wheel on and check clearance. 6000 miles on my 05 Eglide and no issues. I did remove the original bumper bolt from the fender tip. Attachment 451109Attachment 451110Attachment 451108
