Accessory switch and it uses?
I have found that the switch that is on the dash board. Has a pig tail and is terminated/left under the seat. There is a Auxiliary Power Port Harley Davidson part number-91843-97 that can be used. There are many uses for this port or connection. 1) What have people used for this switch? 2) If the power port is used how did you mount it and where? Just looking for possible uses. Thanks
the plug also has power from the P&A fuse and the brake light on other pins- there are all kinds of uses.
my electraglo saddlebag latches run off that plug- but on the P&A and brake pins
for those of us who want power up front for phone or GPS there is an unused power source attached to the headlight wire loom, the org/wht capped wire
Received 1,504 Likes
