Stock wire routing under the rear fender for a street glide tri bar.
I have an '06 EG Classic. I have just converted over to a street glide rear fender and fascia. I see where my new wiring for the tri bar is supposed to plug into the stock wiring on the left side of the bike. My question is does anyone have a pic of the under side of their fender that shows where the tri bar wire routing is suppose to go. And any clips that are to be included. I have found nothing regarding the correct routing. Thanks.
https://cimg9.ibsrv.net/gimg/www.hdf...db70a4a57a.jpg https://cimg7.ibsrv.net/gimg/www.hdf...9f268119fb.jpg Stock plug that I believe was once used for tour pak lighting. This is where the tri bar plugs into. |
My 09 runs on the outside (left side). There are clips to hold the wiring behind the filler panel section of the tri bar facia.
Originally Posted by cncmike
(Post 14740932)
Does Harley have an actual assembly manual that shows the routing.
1 Attachment(s)
I added the street glide fascia to my road king fender. You can see the little clips right next to the bolt holes in the fascia, the wiring will run up the outside of the fender. Not sure where it goes from there though....
The dealer has an adhesive back rubber channel the wire can run through and "stick" to the inner fender. Might have to have them look in the 14 up books. That is what I did because I didn't have clips to secrure the harness. It is a round channel that you are "supposed" to run the wires through before you put the molex connectors on. I had to slice the channel lengthwise near the adhesive, opened it up, pushed the wire into it, then cleaned the inner fender with alcohol and adhered it to the left side.
One side note. I had to get a streetglide harness to replace the roadking harness as they were different. https://cimg9.ibsrv.net/gimg/www.hdf...337373f25c.jpg |
Originally Posted by Magnut1
(Post 14741993)
Originally Posted by RistoRap
(Post 14741958)
An '09 fender is completely different than an '06 fender including the wiring. On an '06 it will run along the top right side inside. You can see the channel on the fender you have pictured. Its why on an '08 and older you have to be careful on oversized tires or using shock lowering brackets as the tire can easily get into that wire housing and tear up the wiring.
4 Attachment(s)
Tgifford5,
I replied to your message, but thought I'd post this as well. The Tri Bar light wiring runs up the outside of the fender on the left side of the bike. It is clipped into the fascia and runs up towards the top of the shock and along the chrome piece and frame ending up under the seat. I have edited your pics to show the tri bar light routing as per the service manual. Inside the left side of the fascia (outside the fender) there should be clips for the wiring - if not you can buy wiring clips shown in one of the attachments at any hardware store. Just attach the clips using the studs that attach the fascia to the fender. (Note: there are no studs on the pic of my fascia as mine is attached with only double sided tape.) And you don't see my wiring as I routed mine to the taillight and attached it there - I did not know there was an existing plug under the seat...... Let me know if you have any more questions of pics. |
© 2024 MH Sub I, LLC dba Internet Brands
