EG outer fairing threaded inserts
Received 47,744 Likes
Here' is one option. You can get them at the HD dealer also
I used a stack of washers with the inside diameter larger than the old insert. Pile them up over the insert and use the original screw and tighten down slowly until the insert starts coming up and bottom out against the screw. Add on more washers until the insert comes fully out of the hole. I did not use any epoxy or glue to hold the new brass insert.
I take a short socket head cap screw 1/4-20 and a nut. Use the nut as a jam nut and thread the bolt into the repair insert and jam the nut. Now, just use an Allen wrench or socket Allen to screw your new insert in until it's flush with the top. The slots are like reliefs cut so as it threads in it kind of self taps the thread. Be sure to hold the boss as you thread in the repair insert. Especially the center one. It wants to twist as you screw in the insert. Hope this helps. Mike Bad
Harley repair insert
Jam nut the socket head bolt to the insert and screw it in.
Better than new.
