Will a 06 or 07 street glide front wheel be a straight bolt on to my 04 ultra?
Trying to upgrade the look of the bike with minimal effort and expense, plus, I like those wheels.thnx.
The 2004 has the same 1" axle as the 06's and 07's, It will be a direct swap. You can go newer up front as well (17"-19") but it would require a bearing change.
I did some research when I swapped out the front wheel on my 06 EGC.
Or, you can switch from a 1" axle to a 25mm axle/spacers and use your old style rotors. That's how I did the wheel swap on my '03.
Not an Airstrike like you're wanting but I did swap to an Enforcer. On the years you mentioned it's a direct swap, but after 09 the front bearings are metric requiring either 1" bearings or a metric axle, and in the case of an Enforcer it requires a later model caliper change since the rotor is a larger diameter.
