Shifter Linkage Came Apart
#52
Hey all-
Is the correct McMaster Carr 5/16 x 24 female Heim Joint Part No 6072K164 (Oil embedded, 14 degree ball swivel - $5.76 ea?)??
Just want to confirm...lots of options for the 5/16 x 24 female Heim Joint on their website.
Thanks in advance. BTW...Great site/resource! Lot's of useful tid-bits there...
Regards
Regards
That particular one seemed to have a good balance between durability and economy , but there are more options available. Plus this one had a nice pleasing gold anodized finish!
#54
#55
A couple of years ago, I upgraded my shift linkage to a chrome one with flames, and it came with a nice set of heim joints.
It made the shifting so much better and crisper.
However, I made a run on the Kancamagus last fall, and right about sunset, I heard a clunk and ping,
sure enough, looked down and the shift rod was laying on the primary.
The nut was missing on the rear bolt.
I had neglected to use locktite on the nuts, but I thought i had used nylock's, but can't really remember.
Was never so happy that I tossed my old shift shaft in the bags with all the bolts, etc.
Sure, I could have used a zip tie, but felt better using the old rod instead.
10 minute fix, and I was on my way.
Lesson learned, if your bolts don't hold up, the heim joints are no fix on their own.
Also it's a great idea to keep the old parts in the bags, along with some simple tools.
You never know when you might need them.
#57
The shift rod lever attached to trans shaft fell off a week ago and had to replace. Used grade 8 hex bolt, it will not come lose again. Decided to upgrade linkage also. Bought this for $7 and a couple ss button heads at ace hardware. Not sure how long these will last as it is susceptible to dirt and grit getting in the joint. The stock linkage has a nice rubber boot.
http://www.ebay.com/itm/271595476180...%3AMEBIDX%3AIT
http://www.ebay.com/itm/390127261695...%3AMEBIDX%3AIT
#59
They certainly wont be over stressed or fatigued. Grit will eventually wear down all moving parts. The ones with a zerk fitting would allow grit to be pushed out and prolong durability. For $3 ea, not concerned, only an observation
