Installing 2016 ABS enforcer wheels on a 2013 ABS roadking
Old 03-24-2016, 04:38 PM
stime63's Avatar
stime63
stime63 is offline
2nd Gear
Default Installing 2016 ABS enforcer wheels on a 2013 ABS roadking
The bike and new wheels are both ABS, but when installing the enforcer wheels they are around .120" too narrow. Has anybody encountered this? What do I need to do to make them work? I know Harley changed the front end setup in 2014 and that the ABS sensor is different between my bike and a 2016 street glide which the new rims came off of. Any help would be appreciated. Jim
Old 03-25-2016, 02:06 PM
Cracker1450's Avatar
Cracker1450
Cracker1450 is offline
Probably going to have to pull the bearings and replace the spacer in the hub.
http://www.harley-davidson.com/store...stallation-kit
stime63 (03-28-2016)
Old 03-25-2016, 03:26 PM
ep120794's Avatar
ep120794
ep120794 is offline
Is this happening on both the front and rear?
Old 03-25-2016, 03:32 PM
lt1-xjs's Avatar
lt1-xjs
lt1-xjs is offline
Should be a direct bolt-on.
Old 03-25-2016, 07:58 PM
KumaRide's Avatar
KumaRide
KumaRide is offline
Installed enforcer take offs on my 2011 abs RKC. Perfect fit.
Old 03-25-2016, 10:33 PM
stime63's Avatar
stime63
stime63 is offline
2nd Gear
Definitely not a direct bolt on and the HD dealer isn't sure without looking at it. Rear wasn't tried yet, stopped at the front wheel.
Old 03-25-2016, 11:07 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,235 Likes on 1,811 Posts
Hmm, .120" too narrow....sounds like that new wheel doesn't have an ABS bearing in it.
The sensor change won't affect the fitment...the Left ABS bearing, Right Std bearing, and center spacer sleeve have been same since 2008 (2008-2016)
Old 03-25-2016, 11:22 PM
BLVN's Avatar
BLVN
BLVN is offline
My dealer installed My 2015 abs wheels on My 2009 in less then 2 hours with 0 issues..
Old 03-26-2016, 01:27 AM
pitbulllimited's Avatar
pitbulllimited
pitbulllimited is offline
Is one of the bearings greenish? I want to say right side, but not sure.
stime63 (03-29-2016)
Old 03-26-2016, 07:04 AM
Hammerhead Pat's Avatar
Hammerhead Pat
Hammerhead Pat is online now
This is the answer.....
Quick Reply: Installing 2016 ABS enforcer wheels on a 2013 ABS roadking
