Repaired an oil leak to the shift shaft seal and while apart I decided to upgrade my clutch. The old clutch did not just slide off. I had to tap it and work it back and forth to finally get it off. Replaced the clutch hub with a new Riveria Primo clutch hub and discs. My issue is, I cannot slide the new hub on. I don't want to bang on it with a hammer. Any ideas? The shaft spline's do not look damaged.
