She's Tight! ....... adjusted steering head bearings
I adjusted the steering head bearings on my 2012 Ultra Limited with 37k miles last night. I turned the bearing adjuster nut a bit less than 1/4 turn. When I checked it at 25k and beyond it was within spec for the number of "swings". Service manual says 3 to 4 swings for my model. Before I adjusted it, it was at 4 swings and a real small extra one. This was out of spec. I decided to check it because when I took my hands off my bars to zip my jacket at 35mph, I had a wobble, the bars wobbeled back and forth with out and hand pressure. Tonight on my test ride, "She's tight"
I noticed right away the entire bike felt tighter, and no more wobble. I guess I did not realize how loose the front end was feeling since it was a gradual deterioration.
The entire process was much easier than I thought it would be.
Basically: I Put bike on my J&S jack and pulled main fuse, took off my outer faring, removed my radio, with CB and Ipod module. This is to get at the steering head nut. I then loosened the steering head nut. I loosened the lower triple tree fork pinch bolts. I again tested the # of swings with everything removed to get a base line. I then turned the adjuster nut clockwise, a bit at a time, while testing # of swings of the front end until it was where I wanted it. I torqued steering stem nut and rechecked swings to see if this changed it, which it did not. Reversed the rest of the process to put back together.
Highwayman-AL (04-30-2016)
Dancemax
06-08-2014 08:28 AM
