Noise on Sidedstand Only. Need opinions!!
Old 05-23-2016, 11:07 PM
bazam9s's Avatar
bazam9s
bazam9s is offline
Default Noise on Sidedstand Only. Need opinions!!
Hi everyone,
My good friend has a 2002 Road King 107K miles (very well taken care of). He experiences a clanging type noise only when on the kickstand. He says it kinda sounds like a shaken spray can. My thoughts are maybe jackshaft, loose primary chain or adjuster.
Heres what I know:
107K miles
95" kit at 67K
SE 6SP trans at 85K
Only hears it while on side stand in neutral.
Does it when motor is warm/hot
Oil is full.
Uses 20-50 Harley oil (non-synthetic) in motor
Redline Primary Oil
Redline Tranny Oil
Sounds is on primary side.
Before I tear into it Id like to hear from anyone that possibly experienced the same or similar issue.
Let me know what you think
Old 05-24-2016, 05:03 AM
Rickierockit92's Avatar
Rickierockit92
Rickierockit92 is offline
I would say just pop that cover off and snoop around... It could be something very simple. Do you know if it's original chain?
Old 05-24-2016, 06:44 AM
DamifIknow's Avatar
DamifIknow
DamifIknow is offline
Check the heat shields on exhaust. Use the KISS method. Did he change something recently? Tighten anything loosen anything?
Old 05-24-2016, 07:16 AM
foxtrapper's Avatar
foxtrapper
foxtrapper is online now
Received 1,242 Likes on 808 Posts
Don't just "tear into it", investigate it. If it makes this noise only on the jiffy stand, and not when standing upright, start with basic stuff. Like dangley things that are now hitting something.
Old 05-24-2016, 08:53 AM
im's Avatar
im
im is offline
I had the round chrome cover on the end of the starter become loose one time.
To the eye it looked fine since the only visible bolt on the chrome starter end cover is in the center of the cover.
That one bolt on chrome cover attached to an under cover bracket that was held with two nuts but one nut was missing causing a rattle noise that was very easy to correct but difficult to identify.
It was identified by getting a clean rubber mallet and taping softly around the bike.
Old 05-24-2016, 11:07 PM
bazam9s's Avatar
bazam9s
bazam9s is offline
New chain and clutch about 70k
Old 05-24-2016, 11:11 PM
bazam9s's Avatar
bazam9s
bazam9s is offline
Thx guys. I haven't heard it and your right to go easy at first and "kiss" I"ll post back if and when I find something
Thx again
Old 05-26-2016, 04:06 PM
00copglide's Avatar
00copglide
00copglide is offline
I have a 2000 flhtpi and in the past had a similar noise...turned out to be the little chrome "cover" on top of the head. Check them.....it's a small Allen head screw
Good luck
Old 05-27-2016, 08:12 AM
cwsharp's Avatar
cwsharp
cwsharp is online now
Thx again
In my case the bolts holding the left footboard onto the frame had loosened up.
Old 05-27-2016, 01:21 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
Check all the easy stuff first: muffler clamps, jiffy stand mounting bracket bolts, if he has hard bags, check the latch screws/bolts for tightness and also check to see that he has not lost any of the bag twist fasteners, check the horn mount bolt, check the exhaust flange nuts, breather bolts, check the heat shield bands for tightness, etc. Check all exterior bolts for tightness everwhere before hauling off and thinking it's internal.
Quick Reply: Noise on Sidedstand Only. Need opinions!!
