Street Glide AUX lighting installed
Old 05-29-2016, 02:16 PM
sanman4ever's Avatar
sanman4ever
sanman4ever is offline
Default Street Glide AUX lighting installed
Purchased kit 69818-06 from Boardtracker. Pretty fast shipping less than a week.
Added 4.5 trucklights to match the headlight. Pretty easy install. Hope they don't need to be adjusted that recessed 9/16 bolt is a pain with the wiring running through it. Got them set up to run with the high beams.
Also have a small gap with the trim rings. Wonder if upgrading the trim rings would look better?
Thinking I might ditch the fog lights now.
Old 05-29-2016, 03:40 PM
GTK's Avatar
GTK
GTK is offline
I have been thinking of putting the aux lamps on my SGS.I have the same fog lamps on the engine guard as you and would leave them on the bike.You can never have to much frontal light on a bike especially in the daytime and you can shut either set off if wired to a accessory switch.
Old 05-29-2016, 03:46 PM
sanman4ever
Yes, my fog lamps are wired to the ACC switch. Also switched the bulbs in those to LED's as well.
Old 05-29-2016, 05:17 PM
bdtaylor1979's Avatar
bdtaylor1979
bdtaylor1979 is offline
Looks good!
Old 05-29-2016, 09:21 PM
druski's Avatar
druski
druski is offline
looks good, been thinking about adding the same to my SG
Old 05-30-2016, 12:13 AM
Onedef1's Avatar
Onedef1
Onedef1 is offline
Careful tightening those to the fairing. I over tightened mine and the bolt popped right through it. Gah... Bet I'll have to buy another complete set to fix it. Fender washer in there for now...
Old 05-30-2016, 05:22 AM
hemi1300's Avatar
hemi1300
hemi1300 is offline
Installed the daymaker reflector auxillary lamps on my 14 sgs a while ago and love them. They throw more light than the headlight itself. For adjusting them, I just took a 9/16" socket and cut a large slot in it with a dremel, works perfect
Old 05-30-2016, 05:55 AM
GTK's Avatar
GTK
GTK is offline
?? Aux lights mount on brackets not on the fairing.
Old 05-30-2016, 06:22 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
^^^Yep^^^
Onedef1, ya got any pics...I think your set-up isn't the same as this kit bolts to fork.
Old 05-30-2016, 08:15 AM
Onedef1's Avatar
Onedef1
Onedef1 is offline
It's the same. The bracket sits on the fairing arms that sit on the fork. Forgive my choice of words. bolt popped right through the bracket. :-(
Quick Reply: Street Glide AUX lighting installed
