Road King is going to cost me some $
My starter drive was crapping out on my 2002 Road King, and I had some oil leaking from behind the Primary. I also had to get state inspection done, so while I was getting the inspection done, I talked to my Indy (great tech) about the leak and starter.
I was figuring on doing the starter myself, but after talking to him, he said that I would have to take the Primary cover off for the starter anyway, so I decided to have him do the job.
"Better come over, got some bad news"...He had the primary case off, looking at the input shaft of the transmission, and front drive belt sprocket. The inner race on the transmission input shaft pn 34091-85, was pushed hard into the shaft seal pn 12035B.
He showed me the special tool that is normally used to remove the race, and from the looks of the tool, there should be about an 1/8" gap between the seal and bearing race...it looks like it had slid in about 3/16" to 1/4". He said "I've definitely seen worse, but its getting deeper than we originally talked, which is why I wanted you to take a look. Until I cut the race off, I'm not sure how much deeper I'll have to go."
I said "Hey, its not your fault, and not much you can do other than fix it right. Its a machine, stuff happens. Keep me informed."
I'm hoping that its not "that bad"...we'll see. With my luck, I'm expecting the worst. 75,000 miles, things happen.
Put the Baker bearing kit in and never have the problem again.
http://crustyoldsite.bakerdrivetrain...ue-bearing-kit
soflafltri06 (06-30-2016)
The Indy was able to cut the race off without further damage, and fortunately didn't damage anything beyond the seal. New seal and race and I'm back in business.
I looked at the Baker instructions and they say to not cut the bearing race, but from the looks of it, there isn't another option, as their tool needs a gap to get behind and pull the race also. I'll put the Baker bearing on the wish list and install the next time I'm in there.
