Electra Glide over the years
#31
#32
#33
Durango Dave (07-04-2016)
#34
I think it's worth mentioning that the early "tour glide" models were much more unique than just the frame mounted fairing. They also had different triple clamp geometry and much more lean angle than the Electra glide. They were an incredible handling motorcycle. I don't believe the modern "road glide" shares those same traits other than the fairing design.
#35
#36
#38
In the early 80's the tour glides had a totally different frame than the electra glides, with a rubber mounted motor and tranny. The 82-up FXRs were based upon that frame. That frame was eventually used across the board for all touring bikes, including the Electra Glide. I think 1984 was the last year for the old frame? Your picture of the 1984 EVO bike shows the new frame.
The touring bikes had two other big improvements before the electric leg in 1965:
Duo Glide - added rear suspension in 1958
Hydra Glide - changed front springer fork to hydraulic in 1949, making the 48 panhead springer a one year only model too.
Of course all Harleys were 'touring bikes' until the k-models in 1952, previewing the sportster of 1957
The following 2 users liked this post by Joe12RK:
BrokeWinger (02-27-2024),
I-94RoadKing (04-14-2021)
#39
Now, hold on a minute!
Misguided as it may have been, no discussion of the 'Electra Glide' family would be complete without touching on the 'Harley/Vetter Liberator'. Harley-Davidson offered the Liberator package as a factory dealer installed option from '74-78. It was a Porta-Potty looking fairing, with a complete dashboard including an AM/FM radio. The immense size of it brought the EG close to a half ton in weight, and did a lot to stimulate the then available S&S Stroker kits to better motivate these barges. The MOCO styling dept., wanting to put their hand print on the monstrosity, even went so far as to specify a GM transit bus headlamp assembly for the fairing! I must admit I had a '78, and once it was stripped down, that S&S Stroker made some impressive Shovel power. I don't know how many they sold, but I do know that 'ELVIS' had one, a '76, and it's still on display at Graceland. (Below)
ELVIS' - '76 ELECTRA GLIDE -'LIBERATOR'
The following 4 users liked this post by JHP:
18deluxerider (04-04-2020),
Durango Dave (07-06-2016),
Jackhole48 (07-06-2016)
#40
