Rear wheel removal with ABS tips?
Searched for an How-To in this forum but no luck. Any videos you recommend?
I scored a nice set of takeoff black ice Agitator wheels and want to put them on. I've done the front wheel before, no issues.
But the rear wheel is a bit more complex. I have the service manual, the torque specs written down and I guess I have to buy a new E-clip? I bought new bolts for the rear rotor (rear rotor and pulley are being swapped to the new wheel).
Harley has a axle nut adaptor but do I really need it? I don't understand their illustration of using it along WITH a torque wrench. The adaptor looks like a wrench and not a socket.
Any tips or links beyond the service manual would be appreciated, thanks.
No, you don't need the adapter. It is used if you don't want to remove the slip on exhausts. Removing the slip ons will make access simple.
A bike lift will also make you life easier getting the wheel back in as you can raise and lower the bike into position.
One think to watch is that you don't drag or strecth the abs sensor cable around when tightening up the axle nut.
Harley does that on purpose so they think most owners will get disgusted and let the dealer do it. It's especially true for their accessory instructions.
Me thinks a Chinaman has written them all. Is that because he made all the parts in the first place?
The best "tip" that I can give is grab a bottle of the old lady's nail polish. And before you loosen the axel, mark them where the adjusters currently are. Great point of reference for when you reinstall. Of course, use the guage on the belt guard, but its probably gonna wind up back exactly where it came off.
Look and think about what you're doing, take it apart slowly and keep your fasteners together, take pics if necessary, refer to the manual if/when necessary. Assembly in the reverse. Main thing is....take your time and think about what you're doing.
This advise has served me in a lifetime of mechanical work. I just replaced the tires on my 14 SGS. I do like the cam type belt tensioner. Much better. Never opened my manual.
Deuuuce (07-17-2016)
