New Lift Master garage door opener...NOW my harley garage door opener does not work...any one else?
Had a lift master 8165 installed...I wired in my harley opener and behold it wont work....Called tech on lift master they say they use new advance signal and a external wired in opener wont work....The opener flashes a error code when i cycle the bright light. SOOOOO has anyone else run into this??? How can i get around this with out getting nother clip on opener that they sell of course that works their door....thats not water proof
http://www.creativeaccesssolutions.com
I found the link call him he will get you all set with the right one. Mine works great.
hopefully you can get an easy fix. I know when I changed mine out I had all kinds of problems with the remotes working. They came back out and changed something and never told me the whole story. Part of what they said had to do with the frequency that it operates.
http://chamberlain.custhelp.com/app/...-my-new-opener
Received 3,988 Likes
Installed a LiftMaster 8500 jack shaft garage door opener in my garage a couple years ago. It didn't work with my Thunderbird's HomeLink internal wireless remote. LiftMaster's Compatibility Bridge solved the problem. Had something to do with rolling-codes. Plugged it into the wall in my garage then used provided hand control to set it up with my car's wireless remote. Works fine now.
https://www.liftmaster.com/for-homes...ELINKBRIDGEKIT
