brake problems
Old 08-12-2016, 08:29 AM
Jeff Hester's Avatar
Jeff Hester
Jeff Hester is offline
6th Gear
Default brake problems
i have a 2006 street glide and cant keep the front brakes to stop leaking down if i pump them up they hold pressure but as soon as you roll the bike a little you have no pressure on the lever. we have replaced the master cylinder bled the brakes with a mighty vac. perlaced all brake lines on the front. the only thing not new are the calibers. cant find any leaking brake fluid.at my witts end with this thing please help.
Old 08-12-2016, 08:39 AM
Neil's Avatar
Neil
Neil is offline
Only two other items I can think of. First, would be the seals in the calipers. Fairly easy job overall. The second, the copper sealing washers at all of the banjo bolt joints. To me it sounds like air is somehow getting in. My first stop would be the calipers. Good luck.
Neil
RDMC
Old 08-12-2016, 09:33 AM
foxtrapper's Avatar
foxtrapper
foxtrapper is offline
Received 1,230 Likes on 804 Posts
Sticking piston seals in the calipers and worn/dirty/sticking brake pads will also do this.
Old 08-12-2016, 01:28 PM
btsom's Avatar
btsom
btsom is offline
Without an EXTERNAL leak, the master cylinder is about the only option. Do your normal "pump up" procedure and then squeeze the lever gently. See if it bleeds down then. I have seen master cylinders that will hold firm pressure but they bypass around the plunger with gentle application. Yes, I saw that you have worked on the M/C.
There is one other possibility and it isn't a fluid leakage problem at all. If your rotor/rotors are bent they will push the caliper pistons farther back into the calipers as the wheel rotates and then need extra movement/fluid to get pushed out far enough to do the needed braking. If your master cylinder checks good and there is no leak, this is about the only other possibility. Has a new tire been installed lately and the rotor bent while mounting the tire?
Old 08-12-2016, 01:40 PM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is online now
Received 47,723 Likes on 18,538 Posts
btsom has pretty much narrowed it down. Did you notice/have any pulsation/surging when applying the brakes? Do you have a dial indicator? Check for run-out (like a warped record on a turntable ). If you have a micrometer you could also check for variation in parallelism ( thicker or thinner in one spot vs another ) If it's not out of spec you could try this. Unbolt the calipers leaving the lines in tact. Insert a spacer between the brake pads to eliminate the "gap" between the pads ( be sure that have spacers in both calipers ) then apply the brake. It will take a couple of pumps to energize the caliper pistons. Then let it sit for a bit ( seconds ). Now activate the brakes and see what you've got. It should be rock solid. If not, it's the master. It has an internal bleed. The original master could have and the replacement isn't functioning properly. Yes it's possible to get a bad master. Hope this helps.
Old 08-12-2016, 04:19 PM
OkieBill's Avatar
OkieBill
OkieBill is offline
Try cleaning your brake caliper pistons. Sticky pistons will give you the exact symptoms you're describing. If there's no actual fluid anywhere, it's the next check and the cost is time only - can be done in 30 minutes.
Lots of info on this elsewhere on the forums. Keep us posted.
Old 08-12-2016, 05:18 PM
geezer glide 56's Avatar
geezer glide 56
geezer glide 56 is offline
btsom and Uncle Larry nailed it,you have a bent or warped rotor or both of them are bent.
Old 08-13-2016, 07:57 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Question
Are you saying that the lever has no pressure, but if you pump the lever you can get pressure for a while, before it goes away? If so you still have air in the system. Try the Sticky in the Tech Brakes section, for a soft front brake.
Old 08-13-2016, 07:59 AM
Uncle Larry
We PM'd ... he has a bent rotor.
Old 08-13-2016, 09:52 AM
grbrown's Avatar
grbrown
grbrown is offline
Thumbs up
Thanks - hopefully all will be fine soon!
Daytona Glider
02-03-2023 07:43 AM
marvincbr
03-11-2012 06:19 PM
tony2x
04-19-2011 04:21 PM
MILLER41143
03-09-2011 03:08 PM
johnk
10-05-2006 01:47 AM
Quick Reply: brake problems
