Cracks in Windshield 2016 Limited
http://www.longrideshields.com/category_s/1832.htm
Great company to work with.
Besides over tightening, a misalignment of the windshield to the inner fairing screw boss when installing can put a small chip in the plastic & then the general vibration will cause a crack to run, usually towards the outside. Also, HD once used US made Lexan poly-carbonate but I've heard they now use Chinese made Lexan. Many of the motorcycle windshield companies use Korean or Chinese poly-carbonate but pass it off as American made. Lexan was once owned by GE Polymer but has been owned by SABIC a Saudi Arabian Co for many years.
Another thing worth mentioning. When installing a w/s look at the pre drilled holes. Are they a clean drill with no chipping or burrs like from being drilled with a dull bit? If so this may make that w/s doomed to fail. Believe it or not, when drilling holes in critical assemblies, such as truck frames for one, they tell you when you scribe a center mark, don't go beyond the OD of the hole because the frame will start to crack. There's a lot of vibration on a fairing so you never know. I've had 2 baggies with a half dozen w/s r&r's and never had an issue. Could be a bad lot of lean w/s's.
I have the same issue with all 3 screws on a '14 Tri-Glide windshield.
I went to the dealer and was told that the insulation was over a year old, I had a Bar and Shield trim bar put on, that it was out of Harley-Davidson warranty.
My point was their service department caused the damage and they should be responsible.
I ordered a Long Ride Shield instead of dealing with them.
Received 2,524 Likes
14 FLHXS 95,000 ride winters in Ohio. I’ve been through about 8 klockwerks 6.5 and 8.5. Stock w/s has never cracked yet and I got a 7.5 windsplitter last year and it didn’t last long. I did run a 11 wide long ride last winter and it didn’t crack. I have never investigated a cause as I don’t wash or do mait much.
