How much labor on brake fluid flush?
Go to Harbor Freight, there's a little hand operated pump for $21.99 and is super easy. If you watch this video, he'll show you how. Max time front and back: 50 minutes. ABS maybe on your bike? I am not a skilled person at all, really is a brainless task. Just get a little a set of open wrench stubbies as you'll use them elsewhere (again Harbor Freight had a metric and US combo set for $11.99).
dafrisco (09-10-2016)
If it were me, I would be more concerned them actually doing it. Sure, the will probably pop the caps and pull off the top and refill. But my guess is that will be all you get. Watch them. Time they pull it in and do it, it will take a half an hour if the really flush it thru. If you pump it thru with the lever or pedal, you will probably do more damage then good since the pistons seals will get into positions they normally do not travel.
The following 2 users liked this post by Just Me:
INJEKTER (04-03-2019),
Zonktified (04-11-2019)
Well, it's probably going to take at least a half hour to do it. So, if they're charging a half hour, seems like a reasonable rate.
Even if it did there's just not a lot of fluid in the anti lock pump. Leaving it in would not seriously contaminate the new fluid. If that bit of fluid does worry you then you can flush the system then ride the bike making a few sudden stops to activate the anti lock then reflush again, more trouble but the only cost is time and fluid.
I've used both a Mighty Vac and speed bleeders to flush bike brakes. I prefer the speed bleeders. The vac works but it's really easy to suck the master cylinder too low. If you do that it's much more time cosuming to get all the air out of the lines.
