RKMCTX4Bulldog - My Ultra's CB
I have a 2008 Ultra Classic, always told no CB but just found out it does come as standard equipment on my model. Yep, it's there, when I looked inside the front cowling. However, it is not recognized and not operable. Is there a code or something to enter to make it work? It only says check with the dealer.....
welcome to the forums- I don;t use CB, but the Ultra models had it and you should be able to use it if you want.
first i would try updating the radio firmware- you can find the how to on the forums and it involves downloading a file and burning a disk on your computer, then putting teh disk into the radio. Once you have latest version software at least we are all on the same page..you'll need mic or headset and CB antenna- you have those? check this sticky too: https://www.hdforums.com/forum/touri...on-radios.html If it is still a no-go you may need dealer help Mike |
| All times are GMT -5. The time now is 07:25 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
