harley touring diagnostic connector wire colors
Old 10-02-2016, 06:38 PM
El Chiguete's Avatar
El Chiguete
El Chiguete is offline
Default harley touring diagnostic connector wire colors
Can anyone confirm the colors of the wires on a touring model diagnostic connector? I've only found this image online and it's actually of a Softail so I don't know if the colors are the same.
The reason why I ask is because when I try connect to this connector on a clients bike I get an error that it can't find the battery power from the plug... and when checking each pin with a circuit tester I'm finding current on pin #1 instead of #4 like on the softail image.
One more thing, does this cable plug in to something or it come out from the main harness? I ask because I want to also check if for any reason this cable was cut and put back together with the wires crossed.
Old 10-02-2016, 07:50 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
This is the DLC (Data Link Connector) for a 2011 Touring Model. The GY wire in connector #91A position #4 is feed off the "Ignition" Fuse. If this is not what you are looking for then please give the year & model of the bike.
Old 10-03-2016, 07:49 AM
El Chiguete
It's a 2013 Roadglide and it has all 4 wires connectors in the DLC. So it's either a different diagram than the one you posted or someone REALLY messed up the wiring there because it has different colors wires too!
Old 10-03-2016, 08:30 AM
14GuineaPig
Try looking here:
Link to illegal bootleg material removed by moderator.
UltraSteveUSAF (02-12-2017)
Old 10-03-2016, 09:35 AM
El Chiguete
Originally Posted by 14GuineaPig
It shows 3 wires for the DLC connector .... good luck
[/FONT][/B]
I think I will need more than a little luck BTW thanks for that EXCELLENT link!!!
Old 02-12-2017, 02:05 AM
Stealthbiker's Avatar
Stealthbiker
Stealthbiker is offline
Stage II
Default speaking of the DLC
i was trying to use my SE Pro tuner and it wouldn't read it - so I looked at it and it only had 3 pins - and not finding anything on the net about being able to replace it - is that possible?
thanks
Old 02-12-2017, 06:37 AM
UltraSteveUSAF's Avatar
UltraSteveUSAF
UltraSteveUSAF is offline
Nice link! Is that available for any other years? I'm working on starting a small business as an Indy and haven't bought all the manuals yet
Old 02-12-2017, 06:43 AM
smitty901's Avatar
smitty901
smitty901 is online now
Received 9,586 Likes on 5,163 Posts
You start messing with those wires and short something you could be buying you client a new ECM.
Old 02-12-2017, 09:20 AM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
MoCo launched a Service Info Portal some time ago.
Useful info on this site:
https://serviceinfo.harley-davidson.com/sip/
More info on the use to be found over here:
Originally Posted by FXD2003Rider
MoCo recently launched a Service Information Portal
Click "Search" in the right hand top corner of the screen and a search box comes up:
Now enter your model, year and the words parts catalog, activate the search engine and a results list comes up!
HDJIM1158
10-10-2018 02:28 PM
Randy Marsh
03-27-2015 07:07 AM
Man In Black
02-17-2010 08:44 PM
HDF Tech
01-03-2006 05:35 PM
pilot1996
General Topics/Tech Tips
06-22-2005 06:06 PM
Quick Reply: harley touring diagnostic connector wire colors
