Andrews 57H install question
Old Oct 11, 2016 | 08:41 PM
B Bop's Avatar
B Bop
Default Andrews 57H install question
This question was probably asked before, if you can lead me in the correct direction I appreciate it!
I'm in process buying remainder of parts for my cam upgrade on my 2012 FLHR Road King for this winters project. I'm going with #09250668 Andrews 57H cams, S&S installation kit for chain drive camshafts #106-5929, S&S tappets #330-0175, S&S pushrod kit adjustable w/covers & keepers #93-5095.
My question: How many flats is the correct adjustment to give proper pushrod adjustment to center of tappet?
I'm aware adjustments (flats) rely on thread count, per-inch and unaware what thread count S&S uses so I'm relying on the experts input setting my project on correct specs.
Thanks, B Bop
Old Oct 11, 2016 | 08:56 PM
SBates08's Avatar
SBates08
S&S are 32tpi. 4 rounds or 24 flats will put you at .130 which is perfect.
QC's Avatar
QC
Here is a link to the instruction sheet. But for the sake of brevity they are 32 TPI and would require 4 turns or 24 flats. I used turns when I did mine because my memory is too short to remember how many flats.
http://assetcloud02.roccommerce.net/...e_pushrods.pdf
Old Oct 11, 2016 | 10:30 PM
Big Money's Avatar
Big Money
4.5 turns
Old Oct 12, 2016 | 06:26 AM
steelpony16's Avatar
steelpony16
FWIW, Pocono Mountain HD was pretty high on the Andrews 57H, they did mine a few years ago, getting good numbers.
Well, come to find out this past weekend they haven't been using that cam for almost 2 years now.
They are using the TTS Cam, comes on at 2000 rpm's. Same HP increase as the 57H but the torque was like 112.
Old Oct 12, 2016 | 10:14 AM
Dguy's Avatar
Dguy
Is that the 100 or the 150? probably the 150?
Old Oct 12, 2016 | 10:15 AM
steelpony16
Sorry, I wish I could remember.
Old Oct 14, 2016 | 07:33 PM
B Bop's Avatar
B Bop
Got it, thanks! One last question: I have the S&S tappets #330-0175 can take these apart and install limit traveler spacers, what is the performance advantage over the stock version?
B Bop
2012 FLHR (Road King) Ember Red Sunglo & Merlo
Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that increases its nostalgic appearance & performance.
Old Oct 15, 2016 | 08:09 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Forget that idea. Limit travel spacers intended for racing applications.
Old Oct 15, 2016 | 10:20 AM
qtrracer's Avatar
qtrracer
With the TTS-100's I've seen 116tq on a stone stock 103" with fm headpipe and rh muffs. 100tq at 2-2200 rpm. They seem to work well, no noise, no drama at all.
