GPR Stabilizer on Bagger
It's called a 'stabilizer', but in fact is a steering damper, which is misleading. In over 40 years of riding Harleys I have never felt the need for one of those. The type of stabilizer our touring bikes definitely benefit from is a handling stabilizer kit such as a True-Track.
Do you have a handling condition you are looking to solve?
Some don't need it (have no idea why). I guess it just depends how aggressive you ride. If you ride15K and up per year any stabilization / heim joint bar that counters the twist from the transmission will help. Alloy Art makes a good touring stabilizer that no matter how hard or soft you ride gives immediate results. Smartest money spent.
Some don't need it (have no idea why). I guess it just depends how aggressive you ride. If you ride 15K and up per year any stabilization / heim joint bar that counters the twist from the transmission will help. Alloy Art makes a good touring stabilizer that no matter how hard or soft you ride gives immediate results. Smartest money spent.
Don't think I had any issues with the steering but have had issues with the typical Harley high speed wobbles.
Have the GlidePro rear mount and Alloy Art stabilizer, tightened my neck bearings and still have the wobbles. With solid front engine mounts the wobble was contained but everything on the bike was breaking due to vibrations. Next step is to replace the swing arm bearings and reinstall the factory parts to see if that fixes it.
