07 Road King 68 Tooth Pulley swap
I have been reading on older threads about swapping my rear pulley out from a 66 tooth to a 68 tooth off a 07 or newer sportster. Just wondering who has done it and which bolts, extra parts needed other than just a new pulley. Pulled my rear wheel to change tire and noticed chrome starting to peel on a couple of teeth, figured time to change. Also anyone that has run this combo for a while have you had any issues, also can the stock belt still be used?
Rimfire03581 (02-22-2017)
No it doesn't have IDS. Do you know what grade of hardware would need to mount the new pulley? I thought about maybe doing the Jap sportster IDS pulley swap, all the part numbers on the forum still seem to be available, one thing that I didn't know was if the sprocket came with the extra bearing? And if it did would it be the right size for my axle. But I think I maybe I should just keep it simple, not to mention a solid sportster pulley are a lot easier to get than a jap one. Thanks
Good question about the bearing size (is it 1" or metric?). It appears it's the same 1" as yours because there is no differentiation of axles on the same 2007 diagram showing both pulleys
You can get the bolts from Harley or other Grade 8 if so inclined
Wish that could work for me . . . Thanks.
