heated grips
I have a 2011 ultra limited. I used large shrink tube. On my heated grips. The reason was different. But what it did was make the grip just slightly bigger which I like. For me it helps with crapping. Reason I did it was the heated grips were sticky which I did not like. If you use the shrink tube. If you don't like it. Just cut it off and you are back to where you started. Cost of shrink tube is about $4 each. I used a heat gun to shrink it. Turned on the heat and sealed the deal. Good luck. Can get it at any good hardware store. Or the interweb.
The following 2 users liked this post by Budda109:
Just Me (02-25-2017),
Sirrobin53 (01-10-2021)
