High Tensile Cylinder Studs
H-D says to use SE High Tensile studs for engines with greater than 10:1 compression.
Anybody had issues with stock studs??
Are they stretching like a rubber band even when set at proper torque and allowing the head to bounce around?
A friend is having trouble with MLS head gaskets and the dealer who installed them says they should have used the High Tensile studs instead of the stock units. I'm skeptical.
If there is a stud problem, couldn't you confirm it by measuring the length to determine stretch?
yes you can measuring the length to determine stretch, but I doubt that is the cast have done several builds set at 10.5-11.1 and not had any problems. I'm in the process of a 124 build and had the cases bored and had the cylinder studs replaced due to the stock ones were removed from the cases.
WEBBiker
Exhaust System Topics
03-12-2007 01:42 AM
