cylinder base leak
Old 03-08-2017, 10:42 PM
HDSAE60's Avatar
HDSAE60
HDSAE60 is offline
Default cylinder base leak
I found a pinched crankcase vent hose and fixed it but the base is still leaking. Is my only recourse to tear it down and replace the O-rings?
Old 03-08-2017, 10:48 PM
Uncle Peepers's Avatar
Uncle Peepers
Uncle Peepers is offline
I have a base leak on an evo, and I just live with it. Might fix it sometime...or not.
Old 03-08-2017, 11:07 PM
HDSAE60's Avatar
HDSAE60
HDSAE60 is offline
It's on a 13 twin cam and leaks enough to drip off both sides after a 100 mile ride.
Old 03-09-2017, 06:25 AM
skydude426's Avatar
skydude426
skydude426 is offline
That would drive me nuts. If it were mine, I'd tear it down and replace the o rings. I don't know how else a person could fix it. Might be a good time for a Fuel Moto 107 kit.
Old 03-09-2017, 06:35 AM
HDSAE60's Avatar
HDSAE60
HDSAE60 is offline
Do I just oil the new rings, slip them on and put it all back together?
Old 03-09-2017, 07:54 AM
roussfam's Avatar
roussfam
roussfam is offline
Received 6,710 Likes on 3,490 Posts
X2 good time for a big bore kit
Old 03-09-2017, 09:23 AM
skydude426's Avatar
skydude426
I would buy an upper engine gasket set because you'll need most of them. Follow the steps for disassembly and reassembly in the appropriate service manual. I don't think you oil the cylinder base o rings. Just make sure everything is clean and be careful not to damage them when reinstalling the cylinders. Don't forget the small o rings for the rocker box oil return passages.
Old 03-09-2017, 10:16 AM
liquidr1's Avatar
liquidr1
liquidr1 is offline
Invest in a service manual. There is a very specific sequence to torqueing the heads/cylinders with a tq wrench. You will also need ring compressing tool to get the cylinders back over the pistons. Other than that, taking the top end apart is easy after you remove the fuel tank.
Old 03-09-2017, 10:29 AM
Ducky 149's Avatar
Ducky 149
Ducky 149 is offline
If you are really smooth you don't even take the cylinder all the way off. Just lift it enough for the wrist pin to be exposed. Remove the circling and take out wrist pin and pull cylinder off with piston hanging out the bottom. Don't know that I have the smoothness for that, but it can be done.
Old 03-09-2017, 11:13 AM
Uncle Peepers
Okay; if I had a dripping, leaky O ring on a newer TC, I'd fix it. I agree with everyone, the service manual is a must.
Also, I'd be interested in why it's leaking. If I got the cylinders off, and the O rings looked fine, I would consider having someone check the trueness of the cylinder bases.
I've done this job, and it's do-able with no special tools. You can compress the cylinder rings with large, worm-drive hose clamps.
Quick Reply: cylinder base leak
