Tour pack antenna connector
My antenna connector wire has shorted. Any one know the nomenclature for that 90 degree locking nut antenna connector? Have had no luck looking up CB or auto antenna connectors on line. Don't know if Harley will sell the connector with a short pig tale I can add a Motorola connector to on the other end.
Thanks, I didn't think of that. They show a complete 102 inch antenna wire with appropriate end connectors which would reach from the tour pack to the radio. I was hoping to find another connector (if I could get the correct name) and splice it onto the wire I have now with a separate connector outside the tour pack to allow a disconnect for tour pack removal. If there is no other choice I can cut that 102 inch cord to about a 2 foot length to splice in.
Thank you. Soldering is not a problem, have had lots of practice. The connector on the antenna has a knurled, threaded ring on it that screws onto the antenna connector making it resistant to vibration. I am accustomed to the standard press together Motorola connectors but never saw one with the screw down ring when searching the net. Will check again. What I find for PL-259 does not match the AM-FM connector, hoped it would.
https://vetco.net/products/car-radio...iVwaAqcf8P8HAQ
Thank you for the interest. The link you provided is for the male Motorola connector that plugs into the radio. I have several male to female connections of that type gong back to the Tourpac. The antenna base inside the the tourpac has an exterior threaded connector with a pin recessed in the center. The antenna wire connector has metal end connected to the ground side and a receptacle inside for the pin in the antenna base for the antenna lead. Near the cable end of the connector is a raised ring. On the cable side of the raised ring is a knurled nut that threads onto the antenna base. This is the first possible example I have found of what I am looking for, it is the connector near the top of the picture.
http://www.ebay.com/itm/Metra-40-VW1...-/302203765074
albngore
01-14-2019 10:25 AM
